G37 RWD in Winter!!
G37 RWD in Winter!!
Planning on getting a G37s Auto and I know I need winter tires. I don't want to purchase new rims so I was wondering if anyone has purchased 19 inch Blizzak LM-60 and put them on the stock 19 inch rims during the winter. If so how do they perform in the snow?
Also, would it be a good idea to purchase winter tires for the rear wheels and leave the OEM tires for the front during the winter?
Always put snow tires on in sets of four. The OEM tires will be worthless in the snow (not to mention REALLY dangerous)
Are you dead set against a second set of wheels/tires? The 18" LM-60 is $20-$40 cheaper per corner and you can get a pretty good wheel for $125. After a few years of seasonal mounting & dismounting you'll be well ahead with having the second set.
Plus the 18* tire is a better performing snow tire becuase of the taller sidewall.
Also consider the LM-25 in 18" that's another $50/ea cheaper.
I am not against buying a second set of rims, just that I don't want to buy rims that I am only going to use in the winter.
What 18 inch wheels do you guys use during the winter and how much did you guys pay for them and where do you guys purchase them from? Will 18's fit the '08 G37s since they come with 19's?
I have a set of 18" rims for my winter tires (Blizzak LM-25s in 225/55 R18). Just make sure the 18" wheels you get have the right offset and will clear the brakes.
Don't even think of using the stock tires when the temperature drops below freezing, regardless of whether or not there's snow on the ground.
Shane D
Would the rear wheel drive G37s be able to get going if there were a foot or two of snow on the ground, given that winter tires are put on the car?
This is the only problem that I am facing in regards to purchasing the vehicle. Any input especially from those who have first hand experience would be very much appreciated.
My snow tire set cost me $600 all said and done. This is for a set of brand new tires on my 08 G37S.
This is what I did:
The G37S's stock rear wheels share the same size wheel as the Pontiac G8 (245/40/19). Last winter there was a ton, and I mean a ton, of a threads for people selling blizzak winter tires on the G8 forum as well as eBay. Most all claimed the ride was too harsh and other claiming they wanted something they could use all year round. yadda yadda.
Long story short, I found a set of Dunlop Winter Sport M3 (for the rears) and a set of Blizzak LM-60's for the front. Both sets are 245/40/19 and while I know the S is a stagg setup... I found absolutely zero issues with this setup and the handling through the snow was nothing short of amazing.
If at all possible, I recommend this setup hands down. The Winter Sport M3's are amazing rear wheel pick up tires and the Blizzak's are great handling and stopping tires.
Hope this helps!
This is what I did:
Hope this helps!
We bought Blizzaks last fall and they made a big difference, still doesn't turn your G into an Xterra but way better than stack. Go with four, you have to have traction while turning and stopping too. I installed them on the same stock rims I use year round. Didn't want the expense of new rims and TPMS hardware. Yeah, I know I could ignore the light for the winter but one I'm not the "ignore" type of person and my wife drives the car daily so I don't want to be without a functioning TPMS system.
This is what I did:
Hope this helps!
This is what I did:
Hope this helps!
My main concern is how much snow will be too much for the G37s even with the winter tires. I have never owned a rear wheel drive nor have I ever used winter tires so I am not sure how much a difference the winter tires will make.
If winter driving is your priority, get a G37X.
Shane D
I really couldn't tell a difference in performance. Granted with different tires, you'll tend to break loose a little more but lets be honest... no one's going to be tracking on snow tires.
I live in Northern Chicago and last year was my first real season with the G and I found that my setup was absolutely perfect. It even let you have stable fun when wanting to play around in a lot or so. Now, granted, most people on here don't live in Nova Scotia Canada where you have 70 feet of snow fall a year but if I lived in that area I wouldn't even try to leave the house if the snow was that bad.
All I know is that during the worst storm (which there is always one big snow storm that hits Chicago each year), the G didn't have any issues plowing through the caked roads with close to 8 1/2 inches on the ground.
