Eibach springs with stock 18" rims
Old 09-01-2010, 06:51 PM
madmax2k1
madmax2k1's Avatar
I'm currently debating whether to lower my car with Eibach springs while sticking with my OEM rim/tires.
The only reason I'm considering the drop is for looks alone since I'm pretty satisfied with the car's handling.
I've read mixed review about the ride of the car after installing springs; I need some honest answers from Sedan owners who lowered their cars with springs and are riding on 18" rims.
How is the ride compared to stock?
Is the harshness noticeable?
Is there more bounciness on the freeway?
When traveling over poor pavements, does it shimmer badly?
Do you regret lowering your car?
Old 09-01-2010, 08:45 PM
kkokko
kkokko's Avatar
There may be added tuck as well when dropped
Old 09-01-2010, 09:08 PM
mindonmatter
mindonmatter's Avatar
I'm doing just that, lowering w/eibachs and sticking with stock wheels. kkokko is right though, your wheels will look tucked in once you lower it. I'm also adding 20mm spacers to fix that. Hopefully next weekend I can post pics and a review. I also had the same worries as you,'but everything I read said that the ride will feel almost the same as stock.
Old 09-01-2010, 11:06 PM
madmax2k1
madmax2k1's Avatar
Actually I already switched to 18" 350z wheels (+30 offset) which are totally flush with the fenders. I would like to hear more feedback about the ride with Eibach springs.
Old 09-01-2010, 11:21 PM
SindhiStyle
SindhiStyle's Avatar
I am curious to know if you are going to need a camber kit or not with the new AWD springs thy just came out with...
Old 09-02-2010, 02:00 AM
platinumg35x
platinumg35x's Avatar
has anybody installed the new awd sedan springs?
Old 09-02-2010, 02:20 AM
adihere
adihere's Avatar
Eibach Springs : NEWS : INFINITI G35X SEDAN 2007-08
Front Alignment:
OE Camber =
-0.35 (+/-0.75 deg)
OE Caster = 4.0 (+/-0.75 deg)
OE Toe = 0.04 (+/-0.04 deg)
PK Camber = -1.7 deg
PK Caster = 4.7 deg
PK Toe = 0.04 PRO-KIT will require PRO-ALIGNMENT kit 5.72130K installed to adjust alignment to OE specification.
Rear Alignment:
OE Camber = -0.25 (+/-0.55 deg)
OE Toe = 0.11 (+/-0.11 deg)
PK Toe = 0.11 deg
PRO-KIT will require PRO-ALIGNMENT kit 5.72265K or 5.72260K installed to adjust alignment to OE specification.
Old 09-02-2010, 08:04 AM
mindonmatter
They may be flush now, but they won't be after its lowered.
Old 09-02-2010, 09:05 AM
SindhiStyle
Front Alignment:
OE Camber = -0.35 (+/-0.75 deg)
PK Caster = 4.7 deg
Rear Alignment:
PK Toe = 0.11 deg
Thanks! I dont know much about camber/toe/etc With a camber of -1.7, how bad will the uneven tire wear be? Is -1.7 horrible? It says the OE camber is -.25 +/-.55? Does that mean it can be anywhere from +.30 to -.80?
Old 09-02-2010, 04:31 PM
terrycs
terrycs's Avatar
I drove around on my stock 18" wheels for quite a while and found the ride to be comparable to the stock springs. Stock springs are linear and Eibach springs are progressive, so the ride quality will be very close. I have some pics here:
G35Driver - View Single Post - My morning at Eibach .
Alignment kits for both front and rear are also now available if interested.
Old 09-05-2010, 06:47 PM
Ron
Ron's Avatar
Thanks for the pic, I now know how my sedan will look! Any info I should know about alignment?
Thanks,
Ron
Old 09-06-2010, 04:52 AM
redG37sedan
redG37sedan's Avatar
I did this same thing and reverted back within 1-2 days. It just didn't look right unless I went with larger wheels.
Also, a major concern was curbs and parking. With a lowered suspension and stock wheels, the front bumper would easily smack directly into the parking curb unless you're very careful. Even if you hit the bumper on a curb once, it'll be a horrible hit.
Ride wise, it was fine. If I were to do it though, I'd go with the 19" OEM wheels and camber kit at front and back. My alignment numbers showed that the car needed camber kits after lowering.
Pics when I had Eibachs:
Side view:
Front driver side wheel:
Old 09-06-2010, 07:54 AM
Ron
Ron's Avatar
redG37sedan,
Thanks for taking the time to post a picture! Are those 17 or 18" wheels?
Your Eibach picture looks different than the one listed above and if my set-up would look the same I rather skip lowering my ride.
Thanks,
Ron
Old 09-06-2010, 02:26 PM
evilpanda
evilpanda's Avatar
Originally Posted by Ron
redG37sedan,
Thanks,
Ron
redG37sedan has 17s.
Old 09-06-2010, 02:35 PM
Ron
Ron's Avatar
Thanks!
Terrycs,
My G37 is like yours with same wheels but in Liquid Platinum. Are you running any spacers in the rear? If my drop will look like yours, I think I'm ok with the Eibach Pro! Do Eibach provide alignment specs?
Ron
Quick Reply: Eibach springs with stock 18" rims
