The T1S Replacements: 2010 Work Gnosis GS-5's in custom finish
Old 07-29-2010, 04:10 AM
loz
loz's Avatar
After all my dramas with my Varianza T1S, i ordered another set of Work's - this time going for something a little classier / less sporty.
This time i opted for:
Work Gnosis GS-5's
Centers finished in satin matte silver
Dish is stepped and finished in machined satin (which has an interesting ripple texture).
20X9.5 +15 BIG BRAKE R-DISK FRONT
20x10.5 + 23 DEEP TIME O-DISK REAR
I would NOT recommend this offset unless you are planning on running it LOW, or have BAGS.... the wheels stick out around 3cm from the guards at standard driving ride height
These photos were taken with my iphone and are just a trial fitment, as there is a bit of guard work i need to do to actually drive on them!
Old 07-29-2010, 07:27 AM
Loi
Loi's Avatar
Looks dope as hell!!good job on making it work!
Old 07-29-2010, 08:35 AM
Blackjack
Blackjack's Avatar
Nice... Looks great.
Old 07-29-2010, 08:39 AM
Wicked_limitz
Wicked_limitz's Avatar
Looks sick
Old 07-29-2010, 09:12 AM
Kidcane
Florida G Club
Kidcane's Avatar
Looks pretty sick! Nice work....finally!
Old 07-29-2010, 09:14 AM
droogie
droogie's Avatar
That is extreme. I guess I don't understand offsets but what makes them stick out at stock ride height but then tuck in when you go lower?
Old 07-29-2010, 09:15 AM
Kidcane
Florida G Club
Kidcane's Avatar
^^Its called camber my friend.
Old 07-29-2010, 10:16 AM
droogie
droogie's Avatar
So as the car goes lower, the camber naturally increases? Doesn't this just cause excessive wear on the tire?
Sorry to hijack thread, but pretty new to wheel/suspension stuff
Old 07-29-2010, 10:43 AM
08blueg37
08blueg37's Avatar
As the car lowers it get more negative camber, and yes it will wear the tires out faster.
Old 07-29-2010, 11:58 AM
VossenG37S
VossenG37S's Avatar
You need camber kits to correct your camber Also I have front an rear spc camber kits an within factory specs , I hate neg camber.
OH and those wheels look Sick as he'll , nice work I'm loving the aggressive offsets.
Old 07-29-2010, 11:59 AM
VossenG37S
VossenG37S's Avatar
What tires an sizes you running btw?
Old 07-29-2010, 12:09 PM
jnguyen
jnguyen's Avatar
looks great Loz, Glad you finally got your wheels! I been subscribed to every single of your thread cause I knew your car had potential
Old 07-29-2010, 12:13 PM
Gamedog
Sam Rothstein
Gamedog's Avatar
Very nice!
Loving all the tastefully modded G's lately
Old 07-29-2010, 12:29 PM
rAiN
rAiN's Avatar
What are you dropped on?
Old 07-29-2010, 06:37 PM
loz
loz's Avatar
Using UAS Airbag kit, with standard shocks at the moment - was running RS-R springs.... i was surprised that the airbags actually drive almost as good as the springs! (but with the benefits of being height adjustable)
in regards to offset : if you are running a spring/coilover setup i would recommend probably +10 more offset for an agressive stance (F+25/R+33) the airbags cause the car to camber in A LOT when dropped hence i could get within a mm of the guards.
As shown in the last photo though, when it's jacked the wheels stick out up to almost an inch, which is (IMO) a bit hecktic for the type of car it is (a g37 isn't a drift car)
Tyre wear wont really be a problem, as the car will simply be aligned to my specs @ my drive height, so the huge negative camber when slammed wont really effect it...
... on another note - the photos above aren't showing it's lowest point, only as low as i could go without mulching the inner guards... (was just trial fitting)
i plan to modify the inner guards this weekend, so the car can sit on the bump stops (should sit around an inch lower that the photos above)
will add photos as i do the work!
Quick Reply: The T1S Replacements: 2010 Work Gnosis GS-5's in custom finish
