spacers for g37s Ichiba or h & r?
Old 06-08-2010, 01:47 PM
popopzer
popopzer's Avatar
Whats good everyone
Looking to grab some spacers for a more aggresive look have my G dropped on eibachs, just interestd to see what everyone is runnning on there G's. I heard the ichiba v2's have vibrations an i def dont want that its seem's the members are going for the h & r ones let me know
Adam
<!-- / message --><!-- sig -->__________________
Old 06-08-2010, 09:35 PM
popopzer
popopzer's Avatar
36 views no comments
Old 06-08-2010, 09:48 PM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
H&Rs.. but depending on the size you'd need to do stud replacement of the OEM ones. vs just bolt on. The ichibas will require the "crush ring" solution if you will be running the stock rims. Kics spacers would be the alternate bolt on spacer to get.
Search for spacers for more info there are a bunch of threads on it.
Oh. Welcome to the forum
Old 06-08-2010, 09:58 PM
yogregb
yogregb's Avatar
I think all spacers are pretty much the same, except some are made hubcentic and others req separate hub centric rings. Some people swear by h&r's, others ichiba's. I think vibrations are more improper installations or wrong fitment. I just ordered 15mm bolt on type 2 ichibas, so I'll let you know when they are installed. Ordered from the vendor section 135.00 shipped
Old 06-09-2010, 12:17 PM
popopzer
popopzer's Avatar
Thanks guyz appreciate it
Old 06-09-2010, 05:50 PM
gbest03
gbest03's Avatar
I've used HR on my FX, and had Ichiba's on my coupe but took them off due to vibrations.
Go with the HR's.
Old 06-09-2010, 08:39 PM
MDG37S
MDG37S's Avatar
I'm using H&R and have used them on all previous cars without any problems.
Old 06-09-2010, 10:51 PM
yogregb
yogregb's Avatar
Go with the HR's.
Were you running factory wheels??
Old 06-09-2010, 10:56 PM
Namir
Namir's Avatar
I have ichiba V2. They vibrate, took them off reinstalled, still vibrate but less than before. Haven't tried the copper crush method yet. Not terribly impressed with them. Two piece spacer/hubring is a fail design. It seems like it was made so that they can just use generic spacers and swap out hub rings, which is what causes the vibration problem.
Old 06-10-2010, 01:32 PM
gbest03
gbest03's Avatar
Yes, factory wheels.
Old 06-10-2010, 03:36 PM
LightsOut
LightsOut's Avatar
the hub rings are not able to be swapped with another size spacer. if thats what your referring to.
Old 06-10-2010, 06:24 PM
ruckus12251985
ruckus12251985's Avatar
i have 15mm h&r and had to swap the studs. i do not have any problem. and i also think they are safer because with the extended stud, when you tighten the lugs everything is tightened together. opposed to the bolt on spacers where you bolt them to the stock studs and then you wheel to the built in studs. if your bolt on spacer is loose you cant check it unless you take the wheels off.
go with the h&r
Old 06-10-2010, 07:48 PM
cereal2k
cereal2k's Avatar
Hey ruckus, do you have any pics with the 15mm H&Rs and did you have to cut your liner? I've got the same sitting in a box, but am thinking of lower profile tires on stock wheels on a vert. Right now, i'm just a little bit tucked.
Old 06-10-2010, 11:02 PM
ruckus12251985
i dont' have any pics with the stocks on(have my dcr's on now), but they fit good with the stocks not rubbing or anything and i didn't have to cut the liner. when i had the 15mm and stocks i was dropped on my coils which were lower than eibach im not sure if the offsets are different on the vert but there was no problems and didn't have to trim or cut anything
Old 06-10-2010, 11:26 PM
cereal2k
cereal2k's Avatar
Ok. Thanks. The vert is just a wee bit heavy. I plan to go with low profile tires when the stockies wear out and will likley have to trim the liner.
Quick Reply: spacers for g37s Ichiba or h & r?
