Help Removal of wheel locks without the key
Old 05-18-2010, 04:03 PM
What's the easiest way to remove tuner aftermarket wheel locks without the key and without damaging aluminum wheels? Like if someone were an idiot and misplaced a key without knowing the brand or key code for said wheel locks? Not calling any names...
I know the "quick freeze" method but it may damage my wheels and studs and I'd like something safer. It doesn't matter if the locks themselves are destroyed because they will need to be replaced anyway.
I pondered if this question should be posted, then I reasoned that locks have never kept a thief from being a thief, they only keep an honest man honest. Meaning that the information isn't going to assist thieves because they already know this stuff and if you aren't a thief you won't turn to a life of crime because you know how to remove wheel locks.
Help is appreciated.
Black Betty is offline
Old 05-18-2010, 04:41 PM
finagle69
finagle69's Avatar
I found a DIY for you.
So, Dont buy a VW - Honda-Tech
finagle69 is offline
Old 05-18-2010, 04:48 PM
TomieG
TomieG's Avatar
TomieG is offline
Old 05-18-2010, 05:02 PM
LightsOut
LightsOut's Avatar
any shop can remove them, easily. My mechanic never asked for my tuner lug nut lock. he always had a universal socket to remove mine.
LightsOut is offline
Old 05-18-2010, 07:33 PM
oreoleo
oreoleo's Avatar
Craftsman bolt out. Might mess the rims up the. Could try to hammer a bigger socket on the key, didn't work for me though (on the oem locks)
GL
oreoleo is offline
Old 05-18-2010, 09:58 PM
itisagoodname
itisagoodname's Avatar
OMG Fail... That however does not look like an OEM lock, especially on the MKV (im a previous owner). These lugs must have been SERIOUSLY overtorqued. Ebay lugs FTL.
Best bet is to take it to a shop, have them drill it out and re-tap the rotor if necessary. This happed to me once with a bent lug, the shop took 3 hours to get the damn thing out.
BY NO MEANS should you ever have to cut up a wheel like that just to get a lug out.
itisagoodname is offline
Old 05-18-2010, 10:05 PM
chris9012
chris9012's Avatar
Why do i feel like this is isn't true about any shop can remove them. it's a wheel lock for a reason I know my gorilla lock has different sizes and theres no universal socket.
chris9012 is offline
Old 05-18-2010, 10:16 PM
Loi
Loi's Avatar
Try this, Amazon.com: Gator Grip' Socket - 5/16" - 13/16" Plus 8mm - 21mm: Home…
and they have them at Walmart.
Loi is offline
Old 05-18-2010, 10:20 PM
GeeeeOhhhh
GeeeeOhhhh's Avatar
Hammer a smaller socket and get a high powered impact wretch.
GeeeeOhhhh is offline
Old 05-18-2010, 10:48 PM
Originally Posted by Loi
This looks promising if it were smaller, it won't fit inside the hole on the wheel though. I'll find out for sure tomorrow. Thanks for the suggestions.
Hammering a 17mm socket on there is probably the best way.
EDIT: I just checked; the ID of the lug opening on my wheel is only .875" and the smaller size Gator Grip socket has an OD of 1".
Old 05-18-2010, 11:13 PM
gan78mao
gan78mao's Avatar
that is just too damn funny!!!!! HAHA
gan78mao is offline
Old 05-19-2010, 12:07 AM
RedG37SNC
RedG37SNC's Avatar
Call the company that made the lugs and see if they have a solution to identify which key you need and order a replacement or perhaps something like this from Wilmar or CTA http://www.brandsport.com/gorewhloke.html
RedG37SNC is offline
Old 05-19-2010, 02:07 AM
Originally Posted by RedG37SNC
Call the company that made the lugs and see if they have a solution to identify which key you need and order a replacement or perhaps something like this from Wilmar or CTA Wheel Lock Keys & Lug Nut Removers: Brandsport.com
I don't know the brand of the locks and I don't think it looks like any of those on the page you linked to. The wheel lock and lug nut remover tools are what I need, but these are too big to fit the opening. However you set me on the right track and I found these that are a small enough OD to fit the holes in my wheels. Thanks Red.
Amazon.com: EMERG. LUG NUT REMOVER SCKT SET--1/2" DR.: Automotive
Old 05-19-2010, 09:37 AM
Kidcane
Florida G Club
Kidcane's Avatar
Just PM someone that lives in NY. They seem to have a pretty good system for removing wheels.
Kidcane is offline
Old 05-19-2010, 09:43 AM
hispeed-lowdrag
hispeed-lowdrag's Avatar
NY thieves FTL
hispeed-lowdrag is offline
Quick Reply: Help Removal of wheel locks without the key
