Vossen 084s and 285s..rubbing?
I decided I will go with a staggered setup for the x and figured that 245/35/20 and 285/30/20 will be almost perfect for keeping the diameters the same. However, will I be rubbing with the 285s in the back? I'm leasing the car so I don't want to need to cut anything to make them fit.
I've been looking through these threads for several days now and searching a lot, but could not find a definitive answer. Some people say one thing and some say another. Also, the search does not let you look up anything that is three characters long such as: 19s 20s 285. This makes everything take a lot longer because you have to sort through hundreds of threads to find something useful.
From what I could find, the Vossens are available in 25 or 38 offset front and 30 or 45 offset rear. I will be sticking with the stock suspension. You think if I go with the 38 front and 45 rear I'll avoid the rubbing?
kinchi
09-25-2015 12:04 AM
