Slow acceleration VOLKGT30 + Nitto Invo
Hi guys,
I'm not sure.. is this normal because of the width of the wheels? or width of the tires? or is it the wheels size?
I have installed days ago VOLK GT30 + Nitto Invo. The sepcs of them are:
VOLK GT30 / Nitto Invo:
Front 20x9.5 / 245/35ZR20
Rear: 20X10.5 / 285/30ZR20
now is it because the tires are heavy? or they normally the 285 are really heavy? or is it because they are Nitto!
What if I go for Yokohama ADVAN front: 245/35ZR20 rear: 265/35ZR20 will the acceleration be back as it was or is it just the same!
many of us are running the same wheels here in the same width, including myself. These are not heavy wheels, very comparable to stock actually. and the tires you are running are pretty sticky so you should notice an improvement in traction if anything.
maybe it's just in your head? should be no reason for slower acceleration
But thinking about it Mike, your overall diameter is still fixed so your rolling inertia isn't changing much is it?
Two objects, of equal diameter and equal weight. Both are the same thickness, and diameter. The difference is, one is solid disk of equal density throughout the disk, and the other is a ring.
If you put them on a slope, which will roll down faster? Equal mass, equal shape, but different inertia.
Haha thanks for sharing bro!
misc
29
05-24-2023 03:57 PM
parkern
10-05-2015 12:12 PM
