Do I need camber kit to install 20'' Vossen 083??
As the title, do I need to put camber kit for 20'' Vossen 83 on my G37x AWD coupe?
What happens if I don't put camber kit?
What if I put 19'' Vossen 83 on my car? Still need camber kit?
Thank you guys!!!
Thank you guys!!!
if your put 19's or 20's is not going to make a difference with the proper tire they end up being the same size. you only need camber kits when you lower your car excessively. with a moderate drop your car can most likely be properley aligned back to factory spec without a camber kit. but when you lower your car more than moderately you will need a camber kit to straighten your wheels out, if you don't you will wear through the inside corner of your tires
Front before: -1.75 camber, 1/16" toe out
Front after: -1.75 camber, 3/32" toe in
Rear before: -2.4 camber
Rear after: -1.9 camber
I'd like to have less negative camber, but I can live with these settings.
