S-tech + Vossen 20's
I ordered everything last week, and I am just waiting for those to come in.
I ordered:
-Tein S-tech
-SPC Rear Camber kit
-Vossen VVS083's Black Machined Chrome SS Lip
20x9 +32
20x10.5 +39
Except the tires.
I think I am going for hankook but I just wanted to make sure the tire size I am getting would work on my setting. (S-tech scares me lol)
Hankook V12
245/35/20
285/30/20
Would this work without rubbing after springs fully settles?
One more quesiton.
I bought wheels pretty cheap from local dealer. I already ordered them but does Vossen provide Lugnuts in the boxes that wheels come in?
or is it something that I have to separately order?
I know vendors here include lugnuts but is it different story if I buy from the local dealer? I never mentioned it b/c I forgot and didn't know.
I ordered:
-Tein S-tech
20x9 +32
20x10.5 +39
Except the tires.
Hankook V12
245/35/20
285/30/20
One more quesiton.
I have 255 on the back with 10.5 with +30 offset with -1.8 degree of camber and I barely have any room, how does 285 with a +39 not rub? He's going to have to run alot more camber than I would right?
I have +30 and run a 275 no rubbing ad spc rear camber arms , lowered on S-techs !!!! hankook 285 I did rub with same drop and spc!!! Do Not run - camber just trim liner and bracket and you good to go! With a + 39 and hankooks 285 yes you will slightly rub cause of tire not offset or drop, I never rubbed with falken 285s but me and Steve rubbed with hankook 285!!!! And Steve went from 305 to 285 then rubbed!!! How did that happen? Well hankook has a bulkier azz tire.
If I want to keep my tire size as it is 285/30/20,
I should go with Falkens and not hankooks?
I know hankook is better than Falken but don't want to risk anything with rubbing.
I want no rubbing at all..
Falken 285? or Hankook 285? : (
With 285 and +39 rear offset it did not rub anymore after alignment and the bracket slightly shaved!!! After I switched to +30 rear offset rubes even more and finally shved as much as possible and now everything is perfect...So w hankook you will have to slightly shave or trim liner/bracket so maybe falken would be more practical or hankook 275/30/20... To avoid shaving or triming and rubbing with the +39
Diaz90 (12-03-2013)
