i was wondering some of you guys installed a staggered setup with 20x10 with offset of 40 on rears on a 2007 g35 or on your g37 sedan.... i wanted to know if some of you are experiencing rubbing with full load of passengers and also lowered with tein s-techs?<!-- google_ad_section_end --> <!-- / message -->
You should be fine. You will need just a tad bit of negative camber (-1.5 degrees), or so. You should have that with the S-techs. Don't go with a tire any bigger than 275/30.
