Help replacing tires on G37S 08 1st time
Hi,
so finally my car reached 20,000 miles yeah I don't use it much, so the dealer is saying to replace the OEM at 20k, I live in Portland, OR so it rains a lot and most of my driving is up to Seattle and back, I was looking at Hankook tires but I seriously have no idea what i'm doing, a little help would be great.
Thanks in advance
Thanks in advance
thanks for the suggestion
so I looked at the RE960A/S Pole Position but it doesn't come in the same size, the OEM comes as 225/45/19 92W Front & 245/40/19 94W Rear.
the closest i found of the RE960A/S are 225/40/19 89W front & 245/35/19 93W rear, is it really that big of difference in size? i guess it would less comfortable?
If they aren't worn don't worry about it. My original tires lasted 30k miles before they NEEDED to be replaced.
I am curious to see how well the RE760 will hold up on a G37 with the 19" OEM rims. I am not liking the replacement cost of the OEM Potenza RE050A ($287 each on Tire Rack).
I've got it down to 2 tires:
RE760 ($206 / rear tire) -- W-rated, treadwear 340 A A
Nitto INVO ($209 / rear tire) -- Z-rated, treadwear 260 A A
I would like to have matching tires, front and back ... I'm sure the OEM front tires will last a lot longer than the rears ... all the torque from the VQ makes shredding the rears way too easy ...
I Have put on OEM and Bridgestone potenza sport but finally for the third set have gone for the much better tread wear of the General tire on tire rack (American version of Continentals). Very pleased so far with this choice.
I've been very happy w/ my Toyos, for an all season they've been great all around tires, and much better grip than the high treadwear rating would lead you to believe.
They have these in the stock oem 19 sizes for the coupe too! Andrew over there gives even better prices if you mention myG37.com
PROXES 4 PLUS Tires by TOYO - Buy PROXES 4 PLUS Online | Tread Depot
Here's a pretty good extensive review
:MoparMax: Product Review - Toyo Proxes 4 Plus Ultra-High Performance All-Season Tire - 8/2/2012
drkashifa
General Tech Questions
08-15-2015 01:27 AM
