20" Wheels w/Stock Suspension??
I couldn't quite find the answer I'm looking for by searching.
I want to upgrade my factory stock 18" wheels with aftermarket 20"s (prob Vossen 082) with the stock suspension but am concerned about the increase causing rubbing or any other adverse effects. How do 20's look on a stock suspension? Also, what tire size would I need? I know some of you peeps have done this, help me out.
Yep
Okay, this is the kind of answer I'm looking for. What's the typical amount lowered on an aftermarket suspension with 20"s?
Where ever you live and how bad the roads are will determine what kind of drop you should put. You should be fine with 20", with the right offset you can still tuck the wheels and not rub. I will be putting 20" and slamming on h&r.
Share more information as to why "eibach in front and tanabe in the rear" and also assuming Vossen 20s what is the right offset for no rubbing? Thx
Eibach is 1.2 front and .8 rear..
Which is why some people use eibach front 1.2"drop (Clean up that ugly front gap) and tanabe rears for a 1" drop (rather than .8) a little more of an even drop..
Hope it helps.
