T1S fits?
Old 12-16-2009, 09:05 PM
gicode0823
gicode0823's Avatar
usually 9.5 on front and 10.5 on rear correct?
i thought that meant how wide it is... i dont know ima noob.
Old 12-16-2009, 09:22 PM
B L U E S L A T E
B L U E S L A T E's Avatar
Width is directly relevant to the offset. Also wheel size. If you go 19s, usually you can run slightly lower offset than the 20s.
That's your goal in terms of aftermarket wheel fitment?
Do you want wider tires? Do you want stretched look? What do you prefer??
Old 12-16-2009, 09:24 PM
B L U E S L A T E
+5 offsets would have fit if you were running 8.5/9.5 setup with some poke and stretch without any fender modding.
gicode0823
gicode0823's Avatar
i want atleast 275 on rear and 19 or 20 depends on rims
Old 12-16-2009, 09:27 PM
B L U E S L A T E
How much camber do you want to run?
General rule of thumb is more negative camber = lower offset. Not neccessarily meaning you won't run or anything, but with more negative camber, you usually have sunken in look on the top. Thus, you'd run lower offset wheels.
Just look at the picture I posted above. That's an excellent example.
Old 12-16-2009, 10:47 PM
STOOF
STOOF's Avatar
If hes local why dont you put them on to test fit.
At least youll get a better idea of how much camber/stretch youd need to fit them.
And take pics
Old 12-16-2009, 11:51 PM
gicode0823
gicode0823's Avatar
so too aggressive meaning have to have crazy camber on them.
Old 12-17-2009, 12:03 AM
TreSe7en
TreSe7en's Avatar
Yes the lower the offset the more you'll have to camber.
It's best if you stay in the 20's with the offset and width of 9-9.5 front and 10-10.5 rear.
Also depends how dropped you are also, the lower you are the more camber you'd have to run.
Old 12-17-2009, 12:08 AM
gicode0823
gicode0823's Avatar
I see... man i dont know what to get lol
Old 12-17-2009, 01:12 AM
TomieG
TomieG's Avatar
Be the first man. Break the wall down!
Old 12-17-2009, 06:53 PM
purebullet417
purebullet417's Avatar
i can picture stoof drooling at the prospect of running that fitment lol. but i def dont think it will fit at least not without massive camber
Old 12-17-2009, 07:59 PM
gicode0823
gicode0823's Avatar
is there anyway to put rear 275 on ssr cuz i like step lip
Old 12-19-2009, 07:54 PM
gicode0823
gicode0823's Avatar
How about this fitment...
19x9.5+15 (clear big caliper) 19x10.5+21
its vs-xx need this on my car :0
Old 12-19-2009, 08:01 PM
  #29
gicode0823
gicode0823's Avatar
and this one
I doubt this one gonna fit since its +0 and +11... I wish thoe...
SSR Professor MS1 19x9.5 +0 235/35/19 19x11 +11 275/30/19
Old 12-19-2009, 08:05 PM
  #30
purebullet417
im pretty sure these will fit with some camber and stretched tires. do you know what size the tires are?
and this one
im 99% sure these will not fit lol +0 will stick way out and 11" wide +11 will be like an inch out past the fender lol
Quick Reply: T1S fits?
