Running same width tires on 19" OEM S rims
I'm shopping the 19" S (staggered) wheels and would like to know if I can run tires of same size on all 4 wheels.
If so, what is the best tire width for this application? I have an AWD Sedan. I did want wide tires in the back but obviously if running all 4 same size the limiting factor is the front. What is the maximum width I can run in the front?
You mean the stock wheels? 17".
The S staggered wheels are 19x8.5" front, 19x9" rear I believe. I'd like to go as wide as possible with the tires but have no idea what that limit is, both for the wheels and the car.
will having the same width tires on F and R reduce the understeer?
I ended up picking up the wheels today. I've decided that I won't do same size all around, so now I need to match front/rear tires.
Just as I had settled on 235/35/19 Front, 275/30/19 rear (within 0.02 inches front/back in total diameter- should be perfect for AWD), I realized that there are two big problems with this setup-
1. They are a whopping 1.25" smaller in diameter than stock. That's a huge difference. I didn't lower the car only to go back to wheel gap
2. The speedometer is going to be ~5% too fast.
The speedometer discrepancy I can live with, but I can't give up wheel space. Back to trying to match up front/rear tires... any suggestions, please share...
