Brakes noise (maybe)
Anyone else getting a wicked loud "dull" metal on metal screeching sound from the brakes when they are rolling in reverse? Not a squeal but a duller sound (if that makes sense). When I back out of the garage I get it (along with the stares from my neighbors) when I lightly apply the brake while in reverse.
I have the same noise, but it sounds like mine is louder. It's embarrassing to have the noise. I had the dealer look at it and they wrote it off as being caused by the metallic brake pads. Bad answer. Any well designed brake shouldn't make the noise. Let us know if you get them to fix yours.
How many miles do you have on it? Granted, I only have around 400 miles on mine, but I have no brake noise issue. However, I have read more than a handful of posts about other people having this problem, more so squealing than what you describe though. If you do a quick search, I'm sure you'll find some other posts regarding this.
First, nice choice with your G. I have the same colors/options.
Per the dealer...try backing up the car as fast as you can (in a safe area), and slam on the brakes. Do this several times to break any glazing on the rotors. From what I can tell, using this method has eliminated the brake noise in my car for now.
Will give it a try BUT mine is doing it in reverse even after driving for hours so not sure "glazing" on the rotors at that point but what the hell it's worth a shot. It's embarassing as is right now.
