Emergency offset help vossen
I've got a great opportunity to get a set of 084 Vossens. Only issue is they are coming off of an IS350 and the offsets are slightly different than most 084's I've seen people running here.
Stats:
20x9 ~ 235/30/20 +38
20x10.5 ~ 275/30/20 +45
I am lowered on H&R suspension. My main issue here is more inner clearance of the barrels than clearance of the brake?
What does everyone here think
Thanks a ton for the help. This is kind of an emergency. Supposed to pick these up tomorrow.
-Steve
Stats:
-Steve
I guess I'll know shortly, but what is your thinking behind why it won't. Someone else here is running vossens exact same offsets and it clears. To my understanding it's the face of the 084 that allows it to clear the caliper. Not the offset.
they will not fit in those offsets. for the VVS084 you need to run a +32 in the front and a +42 in the rear.
you can buy these from the IS and run a 3mm spacer in the rear and a 6mm spacer in the rear.
ck1109
10-15-2015 11:06 PM
