i used to have 5s all around on my sedan and had 5s in the front on the 37, and it was fine, the hub is 10mm so putting the 5 on there still leaves half the hub for the wheel to balance on.
Now hopefully I have enough thread on my lugs to grip well after adding the spacers. I think 6 threads is the least I want to go ... Got to ask local tire/rim shop for that one.
Both...i was thinking of doing spacers and im ordering camber kit soon. Oh yea im slammed on oem 19s.
For no vibration you want hubcentric spacers what ever brand you pick.
I would pick a good name brand like Eibach or Ichiba. Beware of Ebay for cheap made ones.
*As a note to this post I found out about using the slip on 5MM spacers you need at least 6.5 clock work turns for your wheel lugs to safely hold the rim on regardless.
I've got stick so Id say 7-8 to be totally safe. Now to find some good quality 2MM or 3MM spacers lol!
