Sevas R77
Sevas R77
I have someone here in Miami selling a set of Sevas R77 20X9 front and 20X10 in the rear, however he doesnt know the offset. They came off an IS 250, does any one know if they will fit?
when you test fit them, put them on and drive around with them, but obviously make sure it clears the BBK first... then see if there is any rubbing, use your best judgment. obviously if you see that it's too aggressive, don't drive off with them since it might hit your fender and etc.... once they "settle" look at the stance and decide from there if you want them
actually the offset could be listed on the inside of the wheel... some wheels list them and some don't... idk how this guy doesn't know, if you're buying forged wheels and dropping $$$ on them, you should know the offsets and widths so it fits correctly. something tells me this might be the cast sevas and not forged...
