looking for 19x9.5 by 19x10.5 pics
I've been searching for pics that show 19.5 by 19x10.5 pics but they don't seem to be too abundant due to the fact that most move up to 20's, but I like the 19" rim, just want it wider. So if you have pics or link to pics that show this setup can you please post up? thanks.
Well let's not get carried away here. The G "is" a perfromance car on a certain level. While its not an Elise, or Zonda, or F430, it certainly is more than a Ford Fusion or Honda Accord. And as for 3-4 lbs, that is quite allot. The old addage in the day I was hot rodding cars was that for every pound added to a drive tire it was like adding 4 lbs to the cars weight. So 4 lbs on each drive wheel would be 4x4x2=32 lbs of weight the engine would feel. Know its been awile since I've heard that addage so don't kill me if its off, but you get the point. I've put probalby 15 different sets of rims on all sorts of cars and drivetrain configurations and in every case if the wheel combo was just couple of lbs heavier it could be felt in suspension reaction, breaking, accleration. Generaly if feels as if lead weights have been added to you're wheel. Now maybe my butt dyno is more sensative, but in my case I never want to go heavier becaue I do think the car has a performance level I want to maintain if not improve and heavier wheels do not accomplish this. Now if you only goal is looks then you have a point.
As for 20's looking better, thats subjective. As for 20" tires being cheaper than 19" tires, I did not know this. Up until this car I've never owned a car with bigger than 18" tires. I do know that every tire i've ever bought that was bigger than the previous tire costs more, but it's been a while so I guess times have changed.
20s weighing near 30 lbs will be about .5 sec slower in the 1/4 than 19s in the low-mid 20 lbs. thats a HUGE difference in speed/acceleration just for some looks. sure if you just want to cruise thats fine, but some of us care about things like handling and performance.
you can have good looks and performance by buying a nice set of 19s or even lightweight 20s.
![Roll Eyes (Sarcastic)](https://www.myg37.com/forums/images/smilies/rolleyes.gif)
While this will help a little, the problem isn't just the weight but where it is located. The 5 lbs removed from the brake disc arround the central hub does not negate 5 lbs added to the rims outer ring. The effects of rotational mass are worse the further away from the center you are.
