Tire pressure question
for those running 245/30/20 vredestein's what do u keep ur tire pressure at? what should it be at? i see the tire says max 50psi but that seems like alot. Is 38-40 psi good?
^^thanks. so when u say cold im assuming u mean before driving and heating up the tires right? sorry im not to informed about psi and stuff. lol i ask cuz i gotta drive to the gas station to get air so the tires will heat up a bit.
Yes he means before you drive on them and warm them up. Just get yourself a nice electronic tire pressure gauge as you do not really want to use the one at the air pump since they are usually not that accurate. They are not that much $. Check them when they are cold before you drive on them. If you need to add 4 pounds when they are cold, just drive to the store and check the tire again and add 4 pounds.
Glad i saw this thread...
Just had my Vossen's installed and the guys set 3/4 tires at 40psi and one was at about 30psi and the TPMS came on about 20mins after driving...
I put the 4th wheel up to 40psi so that is where they are all at... When accelerating the butt like jiggles a little (never good, lol) Is this because i have too much pressure in the tires?
Just follow the recommended pressure listed on the door jamb of the car. The tires themselves don't have a recommended pressure stamped on them. As stated, they show max pressure is the tires cold pressure design limit for safety/failure purposes which is typically much higher than the normal cold pressure.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
slotterjordan
08-10-2015 12:17 AM
