Waht cars have similar offsets to the G37?
Old 06-03-2009 | 05:04 PM
TJHG37S's Avatar
TJHG37S
I'm about to have some 2pc forged wheels up for sale but I'm not sure they'll be that popular w/ the G crowd as they're chromed, so what other cars have similar offsets and can accomodate 20s?
I'm pretty sure the that Lexus has similar offserts as I've seen some with OEM G37 19s on them and it fit pretty well, but not sure what other vehicles would also work?
Trying to cast as wide a net as possible for these wheels as they're more luxury than sport
Old 06-04-2009 | 05:34 PM
jran76's Avatar
jran76
Some Lexus models (IS350 etc.) and Ford Mustangs, but it would help if you know the actual offsets. You should also note the center bore. Nissan uses a 66.1mm bore, and if the wheels are custom made for an Infiniti with the 66.1mm bore, they will not fit a Lexus (Lexus uses a larger center bore).
Most wheels have a 73.1mm bore and you can use a hubcentric ring to make it whatever size you need. If the wheel is made for Infiniti with a 66.1mm bore, you are pretty much stuck with running them on an Infiniti.
JRW370
Buying & Leasing
04-08-2019 10:24 PM
JakeG37
39
10-19-2015 12:09 PM
Ihtbealexxx
08-09-2015 04:30 AM
TakmaN
08-08-2015 08:47 PM
