spc rear camber kit, more negative, and lower it a bit more if anything, that will take care of the issue. Cut your lining inside, and perhaps that metal thing that is between the fender and bumper, dremel it out.
Lining was totally removed and metal thing was cut, its just that my offset is aggressive but it rubs very little. I might run the spc for more negative camber, I LOVE THE LOOK!
Yeah when you get the spc, it should solve the issue. Tire ware svcks a bit, but it's worth it for the looks.
How did you the cut the metal thing? Did you dremel it? Also, don't our fenders come pre-rolled? Or did you pull it?
Nice set up though it looks badasss man. So are u and wes the ones holding the record right now for most aggressive? Siick
