VA_ How do you even get -30 to fit I'm assuming a lot of body work is needed? Looks mean as hell though.
thanks soolman,
original offsets on fronts were -10 then I added 20mm ichiba spacers
I'm running 215/35/19 and -5.5 camber. Believe it or not it wasn't that much of a body work, rolling deep and sharp turns just naturally pulled out the fender just enough.
thanks soolman,
I'm running 215/35/19 and -5.5 camber. Believe or not it wasn't that much of a body work, rolling deep and sharp turns just naturally pulled out the fender just enough.
Thanks for the info. I'm always curious to know how such aggressive setups are pulled off and not everyone is willing to share.
Sooooo after some multiple height adjustments i finally diled everything in and very happy with this current set-up! I finally got aligned today but keep in mind i removed my front camber arms from spc and went back to stocks! Also i installed new Stance GR coilovers and was in need of realigning badly lol.
Here are my current specs.
Height: 25 1/2 Fender to Ground.
Camber: 2.6 F & 2.8 R
Tires: Hankook V12s 255/30/20 F & R
Wheels: Vossen CV7s 20x10.5 F & R
Offsets: +15 F & R
{Front Fenders Rolled}
ABSOLUTELY NO RUBS! NO TROUBLE TURNING LOL! JUST FLAT OUT AGGRESSIVE AND BEAUTIFUL.
