Question: Is there an easy way of swapping tires without destroying the thread ?
I noticed that everytime i swap winters to summers, and mount and dismount the rims, it has the tendency to scrape the threads on the bolts. Im just worried that one day i'll scrape it hard enough and damage the threads.
Any tips ??
Any tips ??
Pick up the wheel carefully and don't scrape it down the stud thread as you put them on or off. If it's too heavy for you to control without scraping the stud a lot, consider getting a cheap floor jack and jack it up directly in front of the studs so you can just push it right on without buggering your threads.
FYI, if they are akready nessed up replacing the studs might be a good idea to keep from messing up your lugs. Studs are only a couple of bucks each.
thanks guys. i was gonna make a cart buy screwing 3 caster wheels on a piece of plywood to use as a moving jack. friggin tires are heavy and i do bench 160 lb in the gym. =\
m3clubracer
26
08-23-2015 11:57 AM
drewfinity
08-20-2015 08:17 PM
