Help New Volk 99b...widest tires, no rub?
Attn wheel/tire gurus! I have a new set of Volk Rays G-Games 99b
Front:19x9.5 +40 offset Rear: 19x10.5 +40 offset
What would be the best sizes to maintain correct ride height and stuff the fenderwells? can I go with 255/ front and 305/ rear?? If so what would be the correct aspect ratio for each front and rear?
If not, then what would be the max width front and rear with correct aspect ratio front and rear? I'm definately going to do a mild drop at some point, but will currently ride on stock ride height.
Thanks for all your inputs!
![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
here you go http://www.miata.net/garage/tirecalc.html
255/40/19 and 305/30/19 will be the closest to stock and within 3%. as for looks, it depends really. check what some of the other guys are running.
mmnjtwa
09-07-2015 02:27 PM
footballmania32
09-04-2015 03:06 PM
