20mm 25mm spacers F & R Vibration Issues
So I used wheel offset calculator and calculated the offset from the Volk Racing Gt30 wheels that everybody has and compared to the stock wheels they stick out 26mm in the Rear and 22mm in the front. Now that is just the wheel itself, you would get different looks, with different tires. SO I put on Ichiba Type II 25mm and 20mm for the Rear and Front. But I am getting vibration around 60-70, has anybody had same issues and came up with a solution?
I have the spacers torque at 90 and my wheels at 80, and I have hub centric rings, they only thing I could think of is that the hub ring lip that holds the wheel is not as long as the stock hub ring.
Any ideas? Please I need help, I tried taking them off and I cannot stand the look at this point.
So either spacer or set of new wheels its a must.
TheIvoryG
09-23-2015 02:06 AM
nbast
09-14-2015 12:39 PM
