bubble on the side of the tire
i just noticed today that thers a pretty big bubble on the side of the front left side tire. what i wana know is this fixable or do i need to change it asap ? anyone know anything about this or has had this ?
It is my understanding that bubbles can't be fixed and the tire needs to be replaced. If it were me, I would replace as soon as possible and avoid high speed driving. I had this happen on a set of winter tires once from hitting a pothole. I think it is a common issue in winter/pothole season.
Actually depending on the cause it is a manufacturing defect. If I could see a pic it would be nice. but if it was caused by an open joint in the tire it is tire warrenty. Goodyear and bridgestone had issues ith this as they only sample x-ray and inspect their tires. While Michelin has 100% inspection of everytire. Bad ones still get through but far far less.
yea, it means u hit a curb really hard...and damaged the inside wires of the tires...therefore all that air pressure inside ur tire is trying to escape through that weak point...
$300 worth risking your life or your passengers life? Your driving a G37, stop being ghetto and get a tire. bubbles can't be fixed. but hey, its up to you. Just hope you dont get killed if your tire blows up while your on the highway at 70mph. It will be a pretty sight
tite_tite
08-22-2015 06:21 PM
