Vossen 084 tire recommendations?
Hi,
What would be the best tire size for Vossen 084 rims? Also cheapest bang for buck brand?
A local store suggested this
general UHP exclaim ultra high performance summer tires
front 245/35/20
rear 275/30/20
Thanks!!!
front 245/35/20
rear 275/30/20
Thanks!!!
tires is too narrow for the wheel, therefore it looks like its stretched
hm.. so will i rub with
eibachs and vossen 084s, 255/35 front 285/30 rear?
It will be on a non-sport 2008 g37
there is another thread that says 255/285 /w ebiachs rubs on big dips
After installing the eibach's when you go to align, tell whoever's aligning not to reduce the camber but to play with the toe to keep the negative camber which will reduce chances of rubbing.. even if, i think it'll rub with your fendor liner not the fendor itself, just take it off..
not if balanced with the right toe
if you're rubbing against the lining its ok.. it does sound painful though lol.. if you're rubbing agaisnt your fendor.. then you need to act
As for tires I havn't treid them out yet but Vredestein Ultrac Sessanta from what I see is geting great reviews thats why I purchased them. Soon as I get my rims and drive on them for a week I'll post a review.
You can get them for around $650.00 - $750.00 for all 4.
