Help Rubbing HELP Please
Rubbing HELP Please
I'm rubbing really badly and I have iForged 20 x 9 and 20 x 10 in rear and 245/35/20 in front and 275/30/20 in rear on the S Drives and I'm lowered on Eibachs. I don't know how I can rub when almost everyone else is running lower springs and a way more aggresive offset then I am.. And I'm not trying to climb hills, just normal driving.. Anyone have an idea on why I'm rubbing? Thanks in advance!
I'm rubbing quite a bit. MOSTLY when someone sits in the back seat then it MAD rubs on almost every bump. And I'm not sure what the offset are but I do know that people are lowered alot more then me and they don't have a problem, not sure how though..
Sam Rothstein
Do you have pics of your set-up? All you have to do to trim the lining is jack the car up to get enough space to get your hand between the wheel and the inner fender and cut the lining along the inside of the outer fender. If that makes sense. Lol
Rolling the fenders shouldn't be needed if you say they aren't too aggressive. Pics would definitely help bro.
Sam Rothstein
Well after those pics, you're right they aren't too aggressive.
Here you go man, quick DIY for trimming the fender lining:
https://www.myg37.com/forums/wheels-...-solution.html
^ That should be all you need to do.
