Work Varianza V5S
Work Varianza V5S
Taking a hard look at these to replace the stock wheels on my G37X. My first choice would be the OEM sport wheels but I need the same size rims all the way around and the cost and the hassle of splicing a set together and ensuring similar quality is too much. Spent a LOT of time looking around and it sounds like Work is a solid brand and this particular wheel looks a lot like the OEM sport wheel, though not quite its equal--but also not nearly as costly.
Thoughts, forewarnings, or applause will be welcome.
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
To each his own.
I'm not a big fan of the black-and-silver version of the wheel you posted, but if you go to the following web page you can see the silver versions which I like quite a but better:
www.workwheelsusa.com/product.php?category=24&wheel=110
the new Work Gnosis are sick...brush lip. and a slightly different lip designed with added strength (lil groove or curl at the end). 30% stronger than the normal reverse lip.
or even new Equips are a better choice
SuicidalG37SGuy
09-10-2015 06:01 AM
New2Infinity
09-09-2015 10:34 AM
