Tire Maintenance Question
He means actually re-mounting the asymmetrical tires on the wheels backwards (not just switching wheels) to put the outside on the inside.
Exactly my point when I posted on this thread months ago. If you dismount the tires and replace outside side to the inside side the tread pattern on the stock Bridgestone's would push water UNDER your vehicle instead of AWAY from it while driving in wet conditions. Not good.
It is asymmetrical.
Tires are not designed to push water out away from the car, but rather outward from the center of the tire in either direction.
See for example:
I don't believe you are correct...I suggest you take a look at a picture of the actual tire. The tire you show in your post is not the RE050A stock Bridgestone. There is definitely an outside and an inside. Look for yourself at tirerack website.
I misstated. It is not directional.
lets imagine this was the left front tire. Rolling forward, it pushes water "left" right?
Now, flip it around so its the right front tire, with the outside still on the outside. It would still push water "left".
The tire is not directional.
The previously shown R888 is run backwards all the time. It is directional. It only matters when standing water is involved.
Suppose, in my crude drawings below, the x's are the outside tread, and the dots are the inside tread. I'm showing tread patterns of the left and right tires:
|x.| |.x|
|x.| |.x|
|x.| |.x|
|L.| |.R|
In this case, if the tires on the left were pushing water to the left, shouldn't the opposite happen on the other side?
