Review Drop + Spacers - Alignment = Fail (Pix)
#31
To be honest, my tire wear is well within the acceptable range (7/16ths on outside, 3/8ths on the inside) and I'm running 1.8 camber on my left rear (1.5 on the right). But I also just installed my spacers, so I guess only time will tell. And I drive like Miss Daisy...
If I were you, before I sprung for the camber kit, I'd just get a real good professional alignment done and see how close to spec they can get. If they can get real close, then you're probably alright. If you're looking at 2 degrees or more camber, or significant toe, then spring for the kit. That's just IMO.
#32
And there was a set of BC coils for 600 shipped in the for sale section.
#33
From what I understand the most detrimental thing to the tires is excessive toe, not camber. Case in point, the oem setup has neg camber built in to the rear yet after 25k miles in my car the tire wear is remarkably even on my rears. My guess is that neg camber has little to do with uneven tire wear assuming that your toe is in spec and the camber is not excessive.
Sam, I thought read somewhere that you never got an alignment after your drop (or if you did, it was at the same time as the drop). If thats the case its easy to understand how your tires got ate up like that. The toe and camber are probably way outta whack and a good alignment (like Andrew's) should get you back into spec. AFAIK if the suspension is within factory specs there should be no uneven wear, regardless what setup you have.....
#34
Nope I haven't gotten any alignment yet because for one, my tires were almost dead by the time I got the springs and needed to be replaced anyways (thought it would be a good experiment) and two, I wanted to do it at the dealer with the next service so yeah I kind of get the idea that alignment is a must
Kojack
10-09-2015 05:53 PM
