Help After Mounting Wheels
After mounting your new aftermarket wheels... can you fit 4 OEM wheels in your car? you CANT right? Than how did you guys bring back your OEM wheels back home? I hope this is clear
LOL, I had to read it twice.
You can probably put one in the trunk and three of them in the back seat. Just cover evrything up to protect the interior.
I once picked up my new 20" tires from the post office and had to put one in the back seat, and another in the passenger seat.
I hope your drive home is short.
If you can get a second car to come with you or get a friend with a truck or crossover, even an SUV. If you have to do it yourself with your G this way should work:
1. Remove everything in the trunk, including the spare which will give you a lot more room.
2. Place the 1st wheel in the space for the spare and place the 2nd wheel on top.
3. Put down the back seats and the other 2 should fit without a problem.
I think this would be the one time you should be glad you had the oem 18s instead of the 19s.
i fit all 4 stock tires in my car with a small suitcase and a case of beer so you should be able to. just make sure you put something to protect the faces of the rims from rubbing.
