VDC light,ABS and Slip light stuck on
My Vdc light , abs and slip light are all stuck on. I dont know whats goin on with that but the car is running normal.. Anyone have this problem or can anyone gimme some ideas of whats up..much help needed...thanks
Check your brake fluid level. Had the same thing happen to me and I freaked out. Turns out the levels were a little low due to the cold weather.
If that doesn't fix it, take a walk around all four corners of your car and rub your finger along the bottom of your caliper checking for leaking fluid. I also had a leaky rear caliper seal. (Ruined the paint on my wheel)
Hope that helps.
PJ
Hope that helps.
PJ
ecu,abs,slip light on
the car is slammed on 20s high flo cats, stillen gen 3. stillen exhaust. carbon hood and trunk n i have previously reset the ecu. checked thebreak fluid and thats all good. I just dont want to bring it into infiniti bc they will just try to pin it on one of my aftermarket parts when I know its not. I had my boy run codes on it and it came up fine so Im still lost here..but thanks for all the help
B Feelgood
09-13-2015 05:56 PM
inspector94
09-08-2015 12:57 PM
