eibachs on 285/25/20
i just lowered the car on eibach pro's and got new wheels and tires. Now im having second thoughts that the rear tires (vredesteins 285/25/20) have to low of a profile and will have to much gap. How much lower will the car sit on tein's? or should i keep the eibachs and get 285/30. From what i've been seeing i don't think the 285/25/ will look good on eibachs!!. and no i haven't put the wheels on the car yet to see how it would look. i'm getting the wheels powder coated.
first of all, tire size should NOT be decided by gap. for the closest overall height to the stock rears you want to run a 285/30/20. so you have the wrong tire in the first place. fix that then decide if you need to drop the car more.
ohh snaps, my bad woady is right. for some reason i forgot that you were doing 20's. you did buy the wrong size rubber. you should get as close to the stock height.
i got the deal with the tires already on the rims. needless to say i was focused on the wheels and what i wanted to do to them i didnt notice the size of the tires. i couldnt believe i made such a stupid mistake when i've been dealing with cars all my life.
no worries. you're probably reading about an 8% error on your speedo right now and you usually want to keep it within 3%. you should even gain about 1-2 inches in diameter when you swap out to a 30 sidewall too so i think you will be happier with the gap then.
i ran 285 25 20 on a 10.5" with tein s techs no rubbing, also the same on eibach pro kit....now running coils and im lower then s techs...no rubbing...also will be raising it a lil for better driveabilitiy...
it also depends on the size, width and offset of ur rims....
another good thing about the vredesteins is they are rounded on the edges and not more squared....wider tire with less chance of rubbing....
i got vossens 084's. i will get them on when i get the wheels back from powder coating. from the pics ive seen on here, being that the eibachs dont lower that much in the rear i cant see it looking good???
-285/30/20 will be perfect fit
-680 mm (26.8'') 1 mm (0.1%) taller than OEM 679 mm (26.7'')
-When speedometer reads 60mph (96.6km/h) actual speed will be 60.1mph (96.8km/h): 0.2% faster (like woody said 3% range)
But your current set is pretty far off...
-285/25/20
-650 mm (25.6'') 29 mm (4.3%) shorter than OEM 679 mm (26.7'')
-When speedometer reads 60mph (96.6km/h) actual speed will be 57.4mph (92.4km/h): 4.3% slower
-285/25/20
skyline i've done the tire calculations a dozen times and yes it's true! i wouldnt bother me thoe, if i thought it would look good. i've seen other rides with the 285/25 and it looked good, but they were lower. i cant lower mine like that being that i always my 2 daughters in the back seat. with that being said anyone interested in a set of vredesteins 285/25/20 and 245/30/20???
NJ to be honest i have no idea what those tires cost new. like i said i got the wheels and tires as a package. they were the ones that vossen used on the photo shoot they did 2 months ago. soolman im doing all flat black with a thin pin strip in white since the car is IP.
optikol
01-28-2016 07:31 PM
User 122320
10-05-2015 03:03 PM
