Rear tire destroyed itself on the highway, have some replacement questions
why will the laugh at him in the first place? no one in the right mind will do that after what had happened to his tires
OP, Check discounttire.com ot tirerack.com for pricing and find what fits your budget. I had a set of Yokohama S-drives and loved them but changed my wheels and they came with tires already. They should fit your budget. Run flats ride like crap generally. You can put a different pair on the rear axle with no problems at all as long as both sides on the same axle are the same tires. Get a camber kit. Was camber the issue with your tire, or was it a defect, road debris, just plain worn out?
Uh, yes they will.
Damn dude I feel for you big time. My tires need to be replaced too, they're probably just as bad as yours but I have even wear all along the tire because of my camber kit. After running -4.1 camber in the rear for 2 only 2 weeks my tires already started wearing out on the inside dramatically. That's why I tell everyone to get a damn camber kit even with the Eibach drop. It's better to be safe than sorry.
My rears did the same thing at 18k. I had steel belt showing for a while then the right rear looked just like that. Just get new tires and an alignment and you'll be fine
Vredestein tires.Performance+ in Long Beach 888 926 2689 I have the 275x35 rears and the 255x40 fronts and love them! Nice and quiet, I've got like 15000 on them and the wear looks great. Less than 900.00 for 4!
oh wow. glad you were ok. you can get a set of kumho tires for like 700ish shipped. i barely have any tirewear on my fronts...same goes for my rear and i have like 10kish miles on them now.
Try Global Tires in Wilmington (310) 816-9300. I just got new rear tires from them Saturday. I got a pair of Michelin PS2's for $140 each, and that was for 275/35/19s. Talk to either Veronica or Cynthia, they'll help you out. Make sure you tell them you're from the G37 or G35 website and they'll give you a better price.
