Tire Pressure for 225/275 (plus zero)
Old 12-19-2008 | 12:17 PM
marsb007's Avatar
marsb007
What is the proper tire pressure for these tires now? Anyone have a clue? Should I just go with the recommendation for the OEMs?
Old 12-19-2008 | 12:44 PM
DiamondGCoupe's Avatar
DiamondGCoupe
What is Max PSI? If they are Performance tires then yes 35 all around would be ok, otherwise go 5 below MAX PSI, less for more comfort.
Old 12-19-2008 | 03:06 PM
marsb007's Avatar
marsb007
They are the Michelin Pilot Sport A/S Plus
245/40/19 max psi 51
275/35/19 max psi 51
I'll be keeping it at 35 all around I think (unless other people have experimented and have an opinion about it)... 45 psi seems like an awful lot...
Old 12-19-2008 | 04:06 PM
BigDan727's Avatar
BigDan727
35 psi is more then enough, Remember the psi will go up 2-3lbs when the tires get warm.
Old 12-19-2008 | 04:22 PM
DiamondGCoupe
PS - 35 PSI Cold
Old 12-20-2008 | 02:53 PM
marsb007's Avatar
marsb007
sweet... i'm getting them installed right now... hope they're better than the stock!
Old 12-20-2008 | 03:43 PM
Ahujadaddy's Avatar
Ahujadaddy
oh dude, i have that same exact tire size and SAME EXACT tires... the new Pilot Sport A/S Plus.... lmk how u like these tires.
The cut through rain like a hot knife through butter, but in the dry while taking turns hard i def notice they are not as sticky as the summers... which is a trade off u hafta give. Also if you launch hard from a light, u def get alot more SLIP. =p
btw... 35 PSI FTW in these tires as well.
Old 12-20-2008 | 05:55 PM
marsb007's Avatar
marsb007
I hear ya... I'll let you know how I like them. I hope they last a little longer than the stocks (I'd like to keep them on until I return the lease).
Old 12-20-2008 | 10:03 PM
Ahujadaddy's Avatar
Ahujadaddy
yeap... they upped the tread rating from 400 to 500 with the new version of the Pilot Sport A/S... shd last AT LEAST 40k miles i would hope.
guess that means the rubber is slightly harder tho too? hence lil bit of extra slippage when launching.
Old 12-20-2008 | 10:06 PM
marsb007's Avatar
marsb007
So far on the drive back home I couldn't help but notice how much quieter these are compared to the worn OEMs.
I stepped on it as much as possible, and so far so good... I couldn't break them loose (I have the 5AT though).
RYs06MT
04-22-2016 12:00 PM
Juancgn33
09-10-2015 08:25 PM
mmnjtwa
09-07-2015 03:27 PM
footballmania32
09-04-2015 04:06 PM
footballmania32
09-04-2015 03:17 PM
