winter tire setup
winter tire setup
i just bought nismo a34 wheels (gunmetal)
19x8.5 front and back
what size tires should i go with for winter setup
i was thinkin about
225/40/19
245/40/19
what would be good?
i was thinkin about
225/40/19
245/40/19
what would be good?
I was going to buy those rims ... but wasn't sure if the offset would clear the front big brake kit (14" discs) on the sport model.
Go with the same tire size all around so you can rotate them (and want greater traction with thinner tires in the back) ...
Post Whore
I have sport package and I run the same winter setup; clears the brakes.
Actually a lot of people do... mostly for the winter. If you check the Canadian section of the forums you would see a lot of 18 inch set ups.
