DPE S-20s Flat Black face, barrel and lip with Athens Blue pin stripe...Finally
#31
Thanks everyone for the compliments...and yes the rears couldve been more aggressive... I think everyones first set of rims could be more aggressive.... at least thats what I hear and read... so next set will be perfect im sure...
#32
your front will probably rub if your wheels are turned and you go over a bump or something. maybe even during hard cornering.. for the front, just look inside the wheel well.. if it's rubbing in the front, it's probably rubbing the metal inside where it's rolled back up, or right on the bottom edge
#33
#37
I actually think the rubbing is on the inside rear. From the picture, it looks like there is room for 11".
A 10" on my sedan sits much closer to flush. To get a 10.5" and still be inside the fender that much might actually mean the rear offset might be too high. This is easy to fix with spacers or installing rear camber arms.
To the OP ... Did DPE recommend the offsets or did your reseller? Maybe you can get free spacers if this is the problem.
Also ... does your car have RAS?
The rear on our late model G35/G37 can go MUCH closer to flush without rubbing:
#40
I do have 4WAS
Its not rubbing the fender... I actually dont have a clue where its rubbin...just have to wait and let it wear a lil bit...
