19 8.5/9.5 +22
would those fit a g37?
reason asking is theres a local set. 18x8.5 +25 & 18x9.5 +30
and i wanted to know if they would fit the g37
anyone?
negative camber means not all of ur tires touching the surface only most of ur inner tires. this causes ur inner tires to wear out faster. in the other words, its angled. if u search my threads u will see tat my rears are angled from the rear theyre not straight up like stock suspension.
[QUOTE=gan78mao;2275008]I think this will fit its close to what i had before. did u search my old threads? ull see how much mine was sticking out from before?
I finally saw your before pics. Mine looks about the same now as when you had yours before the drop. Exactly how much fender pull was needed for you to clear the rear? (If any was needed at all...)
Thanks!
Thanks!
ya my journey does not have the sport brakes.
im probably going to try them on before i buy them. the guy is local.
but i dont know if its a good deal though
bronze nismo lmgt4
nitto 555 245/40/18 65% 275/40/18 90%
18x8.5 +25 18x9.5 +30
he wants 1k plus my 18inch stockers
what do yall think
bronze nismo lmgt4
what do yall think
bronze nismo lmgt4
what do yall think
bronze nismo lmgt4
what do yall think
[QUOTE=Black 6MT;2275083]
the fender pulll was required. my shop did it to the point that it totally cleared. it pretty much only cleared only on sheet of paper.make sure ur shop knows wut they are doing. i also had to cut this one piece that connects the bumper and the fender which is pretty much useless tat sticks out to prevent it from ripping the tires.
Thanks!
Thanks!
#29
[QUOTE=gan78mao;2275139]
Thanks for the info
Wow, you are barely clearing but great work. Atleast you got your car exactly the way you want it
