FAQ about what size/offsets to get on Aftermarket Wheels...
#31
here are some measurements for the G37S. Form is from Forgeline's website. We are in the process of ordering a custom set. Measurements taken with suspension loaded, factory.
here is the link for the form: http://www.forgeline.com/fitment.pdf
1. F - 3" R - 3 1/8"
2. F - 7 1/4" R - 8 1/4"
3. F - 1 7/8" R - 3/4"
4. F - 8" R - 7 1/2"
5. 67.1mm
6. 3/4"
5. 67.1mm
6. 3/4"
#32
5. 67.1mm
6. 3/4"
5. 67.1mm
6. 3/4"
nice. thanks for that info
#35
G37 Model: Sport 6MT
Rim Brand: Maya
Rim Model: MRS
Front Rim Size: 20x 9 (255/35/20)
Rear Rim Size: 20 x 10.5 (285/30/20)
Front Offset: +30
Rear Offset: +29
Lowered: No
Lowering Brand: Stock
Do you Rub: Yes
Where: Rear Outer wheel well only when hitting dips and bumps hard- also gets worse when more than one person in vehicle. No rubbing in front.
Camber Kit: N/A
Spacers: Yes, 10mm Ichiba spacers in front only
Rim Brand: Maya
Rim Model: MRS
Front Offset: +30
Rear Offset: +29
Lowered: No
Do you Rub: Yes
Camber Kit: N/A
#36
5. 67.1mm
5. 67.1mm
#38
1 inch = 25.4 mm so a wheel 1 inch smaller would be set in 12.7 mm at the same offset. With a 6 mm offset difference the 8.5 inch wheel will be set in 6.7 mm more then the 9.5 inch wheel. This comes to a little over 1/4" which is not a big difference. To have the same look the 8.5 inch wheel would need a 22 - 23 mm offset
#39
4DRZ
Engine, Intake and Exhaust
12
05-18-2017 11:25 AM
parkern
10-05-2015 12:12 PM
flyingnimbus
10-03-2015 12:12 AM
