Put 275/35ZR-19s on original rear wheels
Old 03-12-2008, 12:04 PM
coladin
coladin's Avatar
Is there any rubbing over bumps?
Old 03-17-2008, 04:50 AM
shumby
shumby's Avatar
Originally Posted by shumby
OK KAHBOOM, Middle lining? The tread on any Michelin Tire ( known in Michelin as the KM) is all the same compound. The tread ends in the shoulder area of the tire. you can see this by a slight coloration line in the shoulder area of the tire. that is where the sidewall rubber ( FE "flank exterior") is over lapped with the tread (KM).
Side note KM actually stands for Kelly Michelin. Not sure if it was the daughter or niece of one of the Michelin Cousins.
I have to retract my statement I made to KAHBOOM. I was wrong. I was doing some research and he is correct. I have worked building tires for 4 years and my fater was head of QC in the michelin plant in Bridgewater NS. I have never heard of this until now.
"Michelin says the PS2's tread is composed of two different compounds. The outer two-thirds of the tread has a rubber compound that's biased to provide good dry traction; the inner third has a different compound that's skewed toward wet traction."
I am sorry I called you wrong on this one. Now i am interested how the extruder handdles these 2 compounds in the manufacturing process. See you learn something new everyday. Once again sorry for saying you were incorrect.
Old 03-17-2008, 08:31 AM
PainProphet
PainProphet's Avatar
Classy apology, the internet needs more people like you good sir. Kudos to you and such.
Also, is it possible I have a buzz of some sorts from the diet mountain dew and add meds I have taken this morning? I'm at work and kinda happy, so I must be. Spoooooky
Old 03-22-2008, 06:18 PM
Ahujadaddy
Ahujadaddy's Avatar
bump for any updates AND pics!
I'm thinking to change out all four with the Pilot Sport A/S tires: 245/40 in the front and 275/35 in rear on stock OEM 19" rims
Old 03-22-2008, 06:24 PM
quart
quart's Avatar
I've posted these elsewhere on myg37, but here is my Athens blue with the 275/35/19 in rear and a set of 10mm spacers.
Old 03-22-2008, 10:56 PM
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
Where did you get the spacers? Do you have them on the front as well. That looks good.
Old 03-22-2008, 10:58 PM
KAHBOOM
KAHBOOM's Avatar
No biggie. I know it sounds wierd I even had to research it thoroughly when I read about it. I was actually somewhat incorrect but close
http://www.tirerack.com/tires/tires....ot+Sport+A%2FS
There are actually three different compounds on the AS. And the more aggressive dry compound is on the sides with the all weather compound in the middle.
I guess that is why the Pilot AS is so expensive too. But I loved them on my G35. The inside ribs wore a little quicker than the outside but that was ok with me for the benefit of having those tires.
Old 03-23-2008, 12:02 AM
I'd be interested n getting your impressions after several weeks of driving. When it's time to replace tires I'm considering going wider on the factory wheels as well. 255/40/19 front with 275/35/19 rear. If there are no clearance or rubbing issues (I doubt there will be) this combo is < 1% difference in circumference from stock sizes but significantly wider. It also gives me choices other than the OE Potenzas.
Old 03-23-2008, 02:53 AM
G37sport
G37sport's Avatar
hey post more pics
Old 03-23-2008, 10:06 AM
Ahujadaddy
Ahujadaddy's Avatar
^^ +2 to both posts above
Have to go wider for more options in tires, i was thinking to get the same size u mentioned.
I thought i could make it the whole summer with the OE tires but i have 15K miles now and looks like i will hafta replace by mid summer.
NEED SOME GOOD SIDE VIEW and CLOSE UP PICS! ...plz =) thank you
Interested in seeing how ride height is affected, wheel gap, and just how "meaty" the tries look.
Old 03-23-2008, 11:39 AM
dmkozak
dmkozak's Avatar
FWIW, 245/40 front and 275/35 rear is the "Plus Zero" correct fitment for our 225/45 fr - 245/40 rr original fitment.
Old 03-23-2008, 12:02 PM
shumby
shumby's Avatar
Plus zero? Please explain I am slow. lol
Old 03-23-2008, 03:28 PM
Either will work just fine, but 255 is closer. Up front the OE size is:
225/45/19 = 4" sidewall, 13.5" radius, 27" diameter, 84.7" circumference, 748 rev/mi.
255/40/19 = 4" sidewall, 13.5" radius, 27" diameter, 84.9" circumference, 746 rev/mi. Speedometer reads 60.1 MPH when actually traveling 60 MPH.
245/40/19 = 3.9" sidewall, 13.4" radius, 26.7" diameter, 83.9" circumference, 755 rev/mi. Speedometer reads 59.4 MPH when actually traveling 60 MPH
http://www.miata.net/garage/tirecalcold.html
Plus zero is a larger tire on the same sized wheel maintaining approximately the same circumference as the original size tire and wheel combination by using a wider tread and lower profile tire.
Old 03-26-2008, 03:49 PM
  #29
Kream
Kream's Avatar
I've been told that going 245/40/19 or 255/40/19 and 275/35/19 will make the front 1.2 inches higher than the rear.
Old 03-26-2008, 04:07 PM
  #30
lowrider
lowrider's Avatar
No - Who told you that Below are the specs of the Dunlop SP SportMaxx Tire. I've bolded and colored the Outer Diameter of the Tire sizes in question. As you can see, the OD is about the same, so there is no issue.
245/40ZR19
(98Y) XL 240 AA A
1653 lbs.
50 psi
10/32"
27 lbs. 8-9.5"
8.5"
9.8"
8.5"
26.7"
275/35ZR19
(100Y) XL 240 AA A
1764 lbs.
50 psi
10/32"
30 lbs. 9-11"
9.5"
10.9"
9.1"
26.6"
Lou
Quick Reply: Put 275/35ZR-19s on original rear wheels
