I still have my Maya STM's from my G35. They are 19"x9" front and 19"x10.5"rear with offset of 30 and 29. They cleared my Brembos but will they clear the BBK on my G37 and with that offset will they stick out at all?
^^You have the same set with the same size and offset? That is frustrating cause a couple people said that they would fit andf few said they MAY stick out a bit. And still no one has said what the recomended offset should be for a staggered and aggressive look.
^ it depends. i had +15 all around and i made it fit with 19 by 9 and 19 by 10. if u have a camber kit u can go negative camber and do a little stretch on the tires and it should make it clear the car. I personally like the aggressive look and tats what i have now. if u dont mind the hassle search for my threads mine were sticking out alot. after a drop u will be suprised!.
