G35 wheels fit the G37?
Parts lady at local dealer says G35 wheels will NOT fit G37 due to size of the rotor/caliper?
My bad for not being clear, I have 19" OEM's, purchased 19" Volks Racing GTAV's in stock width. I understand that my OEM's WILLNOT fit the G37, but, because wheelautohaus ordered me Hi-pass wheels in my GTAV's that they WILL fit if I move up to a G37
The G37S wheel specs are:
Front: 19 X 8-1/2 Aluminum/43 mm
Rear: 19 X 9 Aluminum/45 mm
The G35S wheel specs are:
Front: 18 X 7-1/2 Aluminum/45 mm
Rear: 18 X 8-1/2 Aluminum/50 mm
G35S wheels will NOT fit over Stop Tech ST-40 4 pot calipers. Therefore I'm pretty sure they will not clear the G37S 4 pot calipers.
The spoke profile is the key to fitting over BBK's or you can cheat by using spacers.
I am working with a company to develop a 6 piston caliper that will work with the stocks as well. it should be more narrow to accommodate some g35 owners converting to the G37. ill get more info.
Tunerz_Store
Brakes/Suspension
117
07-16-2018 03:04 PM
