BAUS | We now offer Paintless Dent Removal (PDR) and Fender Rolling!
BAUSauto | Info@BAUSauto.com | 626.592.3103
2115 Troy Avenue South El Monte CA 91733 | MON-SAT | 11AM:5PM
h e l l o:
We will now be offering PAINTLESS DENT REMOVAL [PDR] and Fender Rolling to MyG37 members at a exclusive price =) The service will be available BY APPOINTMENT ONLY - As of right now we will be mobile to remove these dents and do rolls. Hopefully this will pick up and become a job where we'll always be available in shop to roll.
Details about PDR is on this post! See POST#2 on this thread for Fender Rolling!
w h a t?
Paintless Dent Removal (PDR) is the technique of removing dents and dings without repainting or replacing any panels. Because no parts are replaced or repainted your car maintains its high resale value, your wallet stays happy, and there is no down time at a bodyshop or waiting for parts! For a more technical description check out the Wiki Page.
To make an appointment please E-Mail us at PDR@BAUSauto.com or Private Message us! As of right now PDR is by appointment only!
d i s a d v a n t a g e s:
Plastic panels such as bumpers and fiberglass/carbonfiber or poly urethane bodykits cannot be repaired. Panels that are designed to collapse upon impact (such as hoods) are sometimes not repairable. Just remember inorder to repair the panel we must have access to it! This leads to another disadvantage, panels such as door and quarter are sometimes more difficult to access so a small hole will be drilled to gain access. This hole will be covered with a rubber plug with the work is complete. Finally, some dents (look like its made with a sharp punch) are not guaranteed to be 100% removable - but we'll do our best and make it look A LOT better!
p r i c e?
$75 for Dings
$100 for deep dings/dings quarter size or larger.
Some dents may cost more to repair depending on the location, size, and type of dent. Unfortunately to provide an estimate for PDR we'll need to see the dent ourselves =( If you can capture the dent on camera please send us a Private Message or E-Mail us at PDR@BAUSauto.com and include your
User Name and which forum
Full Name
Contact Phone Number
In the body of the e-mail! It is very important you let us know you are a forum member to get special pricing!
If we're unable to accurantely quote you through the pictures you sent. We have no problems coming out and looking at your dent in person! We charge a non-refundable fee of
$25 to come out to Los Angeles County
$35 to come out to Orange County
If you choose to repair your dent the $25 or $35 fee will be applied to the repairs.
SCROLL DOWN for FENDER ROLLING INFO and pictures!
-Eric|626-592-3103
BAUSauto
w h a t?
Fender rolling is the process of "folding" the lips on the inside of your fenders/quarter panels upwards and flat against the inside of your fender well. It allows you to run wider tires, wider wheels, lower offset wheels without you having to worry about cutting your tires and possibly resulting in a blowout. Unlike fender cutting or shaving rolling helps maintain some structural integrity in your fenders.
To make an appointment please E-Mail us at Rolling@BAUSauto.com or Private Message us! Fender Rolling is by appointment only!
r i s k:
You run the risk of having your paint cracked if you've had that panel repainted before. Unfortunately no matter who or where you've gotten your car repainted at you'll run a a higher risk of cracking your paint if it has been repaired before! Another important factor is your paint condition, if you already scrape you've probably scrapped away some of the paint on the inner fender, this also incrases the chance of paint cracking.
Another disadvantage is for those wanting to get their fenders pulled/stretched/flared. Once the metal is stretched you will NOT be able to return it back to it's OEM form. This does NOT apply to fender ROLLING.
p r i c e?
$50 for Front Fenders (Left & Right Side)
$70 for Rear Quarters (Left & Right Side)
For mobile service: You must have a safe place for us to work at! We will need to REMOVE your wheel to roll the fender!
+$25 to come out to Los Angeles County
+$35 to come out to Orange County
This includes,
Prepping and cleaning the surface prior to rolling.
Removing any screws and brackets that will interfere with rolling.
Heating the paint properly with a heat gun.
Use proper fender rolling equipment.
The entire process takes about an hour for a pair. Rolls are all done completely flat unless otherwise instructed. Please E-Mail us at PDR@BAUSauto.com or Private Message us to schedule an appointment. And dont forget your wheel lock keys!
SCROLL DOWN FOR PICTURES!
-Eric|626-592-3103
BAUSauto
To make an appointment please E-Mail us at Rolling@BAUSauto.com/PDR@BAUSauto.com or Private Message us! Fender Rolling is by appointment only!
-Eric|626-592-3103
BAUSauto
mmnjtwa
09-07-2015 02:27 PM
