Air Teaser
Old 05-03-2010, 09:38 PM
STOOF
STOOF's Avatar
Originally Posted by beezy619
So what air system is this? I remember a while back you were looking into a different other than UAS or air runner. Do you have any pics of how you setup the tank and compressors? Looks sick btw.
These are bagyard bags and struts. The rear struts are the same overall length as the oems but compress 4" lower. The fronts are 1pc air struts, they will go lower and higher than any bag over coil setup. And the ride is exponentially better since they are valved for an air bag and not a spring.
I pieced the management together myself.
Once i get the fronts im gonna make a full build thread. but since you asked heres 2 pics of how i did the trunk, the tank is colormatched now though.
Old 05-03-2010, 10:25 PM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
Looks hot man! How will you make this happen on a vert? That's the question
Old 05-03-2010, 11:42 PM
beezy619
beezy619's Avatar
Nice setup bro. Thanks for the trunk pics. Your trunk liner looks sick too!!! Price wise, how does your setup compare to UAS?
Old 05-04-2010, 10:53 AM
STOOF
STOOF's Avatar
This can be done on a vert, the rear bags will fit the same, the fronts will fit the same, the only difference is the rear struts, so those need to be made.
The biggest problem i see is where to put the tank, since you quite literally have no trunk with the top down. Id have to be able to get in there and see exactly how much room is under the roof once its in the trunk.
Well, to compare the price you also have to compare the quality. Im NOT saying UAS is bad quality, but their kit comes with lower level stuff.
For example, they just use a switchbox($100) so you have to manually control each corner, im using a computer($1000) so i can manually control it and also have 3 presets and it learns the car and raises it based on certain knowledge. Also they provide 8 individual valves, im using a valve manifold, much better.
Their kit doesnt even come with gauges so you have to get those too.
Heres my parts list:
5gal aluminum tank
2x Viair 400c compressors
Ridetech BigRed 3/8" 4way valve manifold
Ridetech RidePROe3
2x SMC 3/8" water traps
SMC fittings
Check out these sites:
Ridetech.com
airassisted.com
VWvortex Forums: Air Suspension
Basically, if you educate yourself like i have and know what each part is you can save alot of money, for what they give you for 2300 i just pieced together for 1750.
If you just take the bags they give you, 600, and pair em up with coils, lets just say 1000. Thats 1600. My bags/struts were 2100. Everything else is can be the same, so i only spent 500 more, BUT heres the big thing, mine come pre-assembled, so i dont have to make any brackets or put anything together, its straight bolt on. Also ill get more range, im laying frame and i can go to stock height, you cant do that with bag over coils, its much less range. Also my struts are valved for air springs rather than coil springs so the ride is incredible.
Old 05-11-2010, 02:09 PM
Haji
Haji's Avatar
Wow, amazing!!!
Love the work stoof very clean.
Old 05-11-2010, 02:26 PM
Exige
Exige's Avatar
That is insane lol
Old 05-11-2010, 03:08 PM
STOOF
STOOF's Avatar
Thanks guys.
New fronts are being shipped out this week so i should be fully on the ground very shortly!
Old 05-11-2010, 03:48 PM
RISKY GUY
RISKY GUY's Avatar
stoofs pimp is strong gonna slap some biotches.
nice work, finally coming together.
now stay away from the potholes on the si xway and your set.
Old 05-11-2010, 04:12 PM
Haji
Haji's Avatar
Don't let the sparks catch you on fire lolzzz
Old 05-26-2010, 03:23 AM
tWistedMissiOn
tWistedMissiOn's Avatar
WOW!! cant believe i missed out onthis thread! AWESOME ride stoof!! i cant wait for the next thread when you get it all set up!!
Old 06-05-2010, 09:45 AM
BOXER83
BOXER83's Avatar
Can you please PM me price you spent for the system and maybe piece a kit together for me?
Old 07-02-2010, 09:05 PM
loz
loz's Avatar
Wow! Super clean setup! Alot of work gone into that boot install! I like!
(and far out, how low does your go at the rear!! crazyness!
You running front/rear camber arms ?
beng37s
12-08-2019 01:21 PM
vamarris
12-09-2018 11:10 AM
BurtoN86
11-03-2015 04:40 PM
BurtoN86
09-30-2015 03:32 AM
Quick Reply: Air Teaser
