TSB - RPM drop? 08 coupe???
Hello:
I am having the issue with the RPMS dropping when stoping...... I know a lot of posts on this and cleaning TB might help... but is there a TSB for this on an 08 coupe? I have an appointment at the dealership for something else on tuesday and would love to get this taken care of to... if possible.
thanks in advance for your help...
Just to update on this… it was a carbon build up on the throttle bodies… they did a cleaning and problem fixed and the car runs great! They also ordered me a new seat bottom for the “bubble but” issue <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Itb11-018 - engine hesitation or stops running at idle or very low speeds
ITB11-018 - ENGINE HESITATION OR STOPS RUNNING AT IDLE OR VERY LOW SPEEDS
APPLIED VEHICLES: 2007 – 2008 G35 Sedan (V36) 2007 G35 Coupe (CV35)
2008 EX35 (J50)
IF YOU CONFIRM
The customer reports any of the following:
• Engine hesitation at idle or very low speeds,
and/or
• Engine speed drops lower than expected when decelerating or coming to a stop,
and/or
• Engine stops running at idle or very low vehicle speeds (parking lot maneuvers), but can be restarted.
SERVICE PROCEDURE
1. Connect CONSULT III (C-III) to the vehicle to begin the reprogramming procedure
2008 EX35 (J50)
IF YOU CONFIRM
and/or
and/or
SERVICE PROCEDURE
aliiin
04-27-2018 10:37 PM
