TSB - Rattle in Main Muffler
#32
2008 INFINITI G37; CLICKING NOISE FROM REAR AXLES
A “clicking” noise is coming from the left and/or right rear axle (driveshaft) when accelerating from a stop.
or
2007-2008 INFINITI G35 SEDAN, 2008 G37 COUPE, 2008 EX35; TAPPING NOISE FROM DASH AREA WHEN ENGINE IS RUNNING
A tapping noise coming from the dash area when the engine is running at operating temperature
or
2008 INFINITI G37 COUPE; NOISE FROM BANK 2 VVEL ACTUATOR
A slight ticking / tapping / knocking noise coming from the bank 2 (driver side) VVEL (Variable Valve Event & Lift) actuator.
or
or
#33
is what I'm talking about.
#34
brought my car in to replace muffler, and told them that my engine is making a loud ticking when the AC is on, rough idle etc. It turned out to be the ecu needed to be reprogramed. BTW, it's not as simple as pulling the battery cable either. the ticking went away, car drives much better.
#35
#36
I took my car in yesterday after seeing that my VIN# falls within range. The rattle for me wasn't even that bad.. the exhaust just sounded louder and more raspy during cold starts. But because I'm picky with my car, I decided to take it in to the dealership. Now I have a new muffler on order and will most likely get it replaced next week
So to those of you with even a slight rattle, it's worth a shot!
#37
Thanks for this info. Took my car in and told them about the off and on mettalic noise I have been having and they said one of the baffles in the exhaust was bad and replaced it. They had one in stock which was awesome.
#39
Think I'm getting jerked around...?
...as I've been told for more than six weeks now that a replacement muffler is on back-order...? I didn't buy the car locally cause the salesman wouldn't deal and is an all-around jerk, plus I saw him lurking around and seemingly scouling at me (not generally paranoid BTW) when I was last in the stealership...
#41
Let us know.
#42
#44
#45
