The M - Spot General discussion for the M35/M45
What is the reason to "stretch" your tires on the rims?
Old 01-06-2012, 02:58 PM
RiA
RiA's Avatar
I see a number of cars with this done and don't understand the reason - can someone explain?
Old 01-06-2012, 03:11 PM
AroundTheG37
AroundTheG37's Avatar
To fit wider wheels.
Old 01-06-2012, 04:06 PM
RiA
RiA's Avatar
But not wider tires? That leaves the rim exposed to more damage without tire protection.
Is this all to get a deeper lip?
Old 01-06-2012, 04:17 PM
AroundTheG37
It's basically for people to try to reach hellaflush status or be somewhere near it. Some people take it to ridiculous levels but most people here pull if off nicely. Lip or no lip, hellaflush does not discriminate.
Old 01-07-2012, 01:10 PM
myk1013
myk1013's Avatar
wide wheels + slammed + wide (proper) fitting tires = tires rubbing, fenders burnt and disfigured
wide wheels + slammed + narrow (stretched) tires = a bit extra clearance to prevent rubbing issues, fender damage, etc..
This is basic info... there's also other factors such as camber/camber kit, spacers, fender pull/roll,
Old 01-07-2012, 02:01 PM
soolman32
soolman32's Avatar
There's some key words in what's been said already. If you truly want know more, Google "Hellaflush" and check out StanceNation.com
Old 01-25-2012, 09:10 PM
tejasg37x
tejasg37x's Avatar
Not to mention a safety issue for the tires...the sidewalls of tires are made to provide support vertically, and stretching the tire making it more horizontal takes away from it's integrity.
Old 01-26-2012, 08:55 AM
RISKY GUY
RISKY GUY's Avatar
It just begs for rim damage or blow out.
Amazed more people don't destroy rims by doing this.
Old 01-26-2012, 09:36 AM
The simple answer is because those dudes are much cooler and more awesome than you are.
Old 01-26-2012, 09:41 AM
Kidcane
Florida G Club
Kidcane's Avatar
Basically they chose form over function.
Old 01-26-2012, 11:16 AM
AroundTheG37
Not to split hairs here but did Infiniti choose that option as well going with stretched tires on the sport version? LOL.
Old 01-26-2012, 11:44 AM
The tires on the sport OEM wheels are not stretched at all. Not even close.
Old 01-26-2012, 12:15 PM
AroundTheG37
They are not stretched in the eyes of the hella flush crowd but they do have a mild strectch, as any tire that goes inward towards the top can be considered stretched. I guess it's in the eye of the beholder.
Old 01-26-2012, 01:08 PM
I understand what you're saying. But some tires naturally have a more rounded shoulder profile and some are more square. Stretching a tire is putting a tire on a wheel that's designed for a wider tire than you're using. Putting the OEM 225 on the 8.5" wide wheel is not stretching at all becasue it is designed for a tire that width. Putting a 195 on the same wheel is stretching.
Old 01-26-2012, 02:52 PM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
Hahaha best answer yet. It just looks awesome for hella flush setups, but is it practical hmmm maybe not depending on the extremes.
You can have both , flush (function) vs hella flush (form)
For proper vert form, you have to stretch it
Sept North GA Mountain run, you know what's up
Quick Reply: What is the reason to "stretch" your tires on the rims?
