I may need to rebuild my engine...
Most likely there is nothing wrong with your pistons. Like I told you weeks ago when I saw the smoke coming from your tailpike and could smell oil burning. It is most likely just your rings are fried. Pull the crank and pistons, hone the cylinders to remove any scuffs and burrs, then replace the rings and your set. Shouldnt be that expensive unless you plan on goin for power. Why replace the pistons if its just your rings?
Mattimus
10-04-2015 01:33 PM
slotterjordan
08-10-2015 12:17 AM
